the boss
He said mid-to-late 2014, likely late. If you don't require ZP, you can get them this year. I spoke to the guy about flat-fix cans and he agrees that they are not the hot setup. Can affect balance of wheel/tire assembly, make a mess inside the tire, and can cause a hazard to a tire changer as the goop can, in some cases, be explosive. That's all we need...<grin>. I'll use up the Goodyear junks and by then I'll likely go with the ZP's. Michelins are quite expensive compared to the competition, but they really are good tires. I just know I can't get another set of OEM's.
As a mechanic, I saw some of those ''fix a flat'' in a can causing problem to tpms sensors. First time it append, I could fix it but the second time, I had to replace the sensor.
