Model Year - 1993Hello,
Data base still active and well. I have added three or four since taking it over. Will certainly add yours too.
Can you tell me the interior color?
tcxd40
Sounds as though someone has been tampering with the system. Maybe decided they could not afford to replace the shocks (or just didn't want to), as they are a high priced item, and removed the switch and related gear.
Seems like the most logical solution. I've only had the car a couple of weeks & still assessing the "to do" list. I bought new wx stripping & have to change the oil & coolant. When I'm crawling around underneath, I'll see if I can take inventory on what's there & what isn't. I know I'll need a console switch for the SRC for sure.
Begs the next question: Where am I in the spectrum of ride settings without the system in play? The little that I've driven, she seems a bit rough but I don't have a point of reference with other Vettes, ZO7 or not. I have not been agressive with it, just normal town driving so far.
I believe that is correct, Dragon. ABS is behind the driver seat.
adThat's a shame. I guess I'll try scanning the PP slide & try to convert it to a jpeg or gif file. Maybe I can upload it then. Not that there would be any renewed interest, but I'll check & try to find an emroiderer & get one made. If it's not outrageous, I make a couple extra's. You can let me know if you're interested after seeing the design. Basically, its' the C4 logo with a Z on one side & a 7 on the other. If we wanted t shirts we could add "The original" above it & "Corvette" below it. That would imply that the C4 was the original ZO7 optioned car. (Is that true?)
I have a 92 ZO7
M6
Black Rose Metallic
Black Interior
Clear Top (Blue)
All original
Build sheet and Window Sticker ($40,014.00)
VIN 1G1YY23P1N5110039
3rd Owner
82,000
Still in love with it!!!!
Many RPO codes were reused, such as ZR1, ZR2, LT1, LS3, LS6, LS7 etc. So whats the point, its an RPO code.,ZO7 was also used 1975 If I'm not mistaken, so the C4 were not the first.
