D
DrNavyRet
During the heat of the summer, my clutch woked perfectly. With the past two weeks of freezing weather, my clutch pedal sticks to the floor after start up and a shift into any one gear. Pumping the clutch pedal and warming up the engine and, like magic, the problem disappears. So my theory is that there is a small amount of ?water? in my clutch fluid. Is there anything that I can put in the master cylinder to safely eliminate the moisture? Or am I all "wet" with my shade tree diagnosis? Thanks in advance for your assist.
The Old Retired Sailor
