Marv02
The Car 1986 C4 with (5.7) 350 2 bolt Main 148000 on the clock.
Ran good compression seem good.
Did not smoke trans was tight but I never happy it’s time to get my hands dirty.
But I purchased this car first of the year it was sitting outside in a field for the last 7 years last time it was ran before I got it was 3 years ago.
Had it running after a week repainted the car in my garage myself trying to save some money New seats New door panels, Rebuilt dash cluster New A/C system New Brakes Rotors Ect new tires.
Now it motor and trans time.
I putting in a 4 Bolt Main 355 motor with the following.
Trick Flow 23 195 heads, Howards cam and lifters 288/288 Duration, 447/447 Lift 110 C/L
Scorpion Roller rockers 1.5
Comp cam push rods comp cam timing set
Kevko hot rod oil pan 7 inch deep pan.
Edebrock EGR, TPI Hi Flow base intake.
SLP Runners
Custom Chip FIC 24# Injectors
Magna Flow Mufflers.
If the numbers are right I should be seeing around 380 to 390 HP and 427 TQ at 5400 RPM's.
Now here some pictures so far what’s been done
But a couple things I can tell you already save yourself some extra cash Make sure you get a R/H oil stick 1 piece crank seal motor I think it going to cost me a extra $300.00 in parts I got a L/H side dip stick my Mess up.
Motor Out
SLP Runners
Motor Out
