R
RedVetteMan
To cool or not to cool (another C4 AC question)
(With apologies to Shakespeare)
Checking out a rattling noise under my hood, I discovered that the AC pulley is broken, and also noticed a little smoke coming from between the clutch and the belt pulley. I suspect I've either fried my compressor or the shaft bearing. The pulley still turns, albeit with difficulty. I've had the car more than four years, and used the AC once, 3 years ago. I don't drive it during the winter, so I've never used the defroster.
So I'm left with these options:
1. Replace compressor/clutch, etc. and have someone recharge the system. I'm hesitant to do this because I never use the AC. I drive it only on nice days, with the top off. No sense cooling the outside air or spending all that money. So this brings me to the next option...
2. Is there a reasonable way to replace the compressor with a slave pulley assembly so I can continue to use the serpentine belt arrangement, or
3. Gut the compressor and disconnect the AC piping?
Any insight from you good people out there is greatly appreciated.
Thanks,
Paul
Thanks,
Paul
