Ryan536
Here is my other problem with my Vette..... It looks like a 4X4!!!! Is it just me? Or is it an optical illusion?
The rear tires are 295 50 R15. The fronts are 245 60 R15. When I bought the car the rear leaf spring had been replaced with a fiberglass mono spring. It also had "knuckles" or chalks stuck in the front coils which I removed but the overall ride height never changed. I can't tell if it has those rubber grommets on top of the coils to increase height. I feel the front is sitting 1 to 2 inches too high. It also looks like the front sits higher than the rear by an inch. The front suspension looks stock but is there a difference in Big Block coils and regular coils? Maybe swapped out at some point?
Any help would be appreicated
