Jayman
http://tpiparts.net/inc/sdetail/1495
VATS Enable/Disable
EGR Enable/Disable
AIR (smog pump) Enable/Disable
Injector Size Specify Size
Fan On/Off Temps Specify Desired Temperatures
Speed Limiter Specify Desired Speed
RPM Limiter Specify Desired RPM
Cold Start Injector Enable/Disable
Hello everyone - can anyone provide feedback on these units. I'm considering picking one up simply because they're affordable and my biggest need is to have the fans come on sooner, not so much for power gains (although it would be nice too).
Just wondering if anyone has used these, how they feel about them and what changes would you recommend on a stock engine? I will probably install a 180* thermostat as far as 'mods' go. Feedback is appreciated here.
Thanks all!
VATS Enable/Disable
EGR Enable/Disable
Thanks all!
