- Thread starter
- #61
I read through my Holley stuff today, and it looks like it's time to clean the electric fuel pump. They suggest every 6,000 miles. I'm past 8,000 already.
67HEAVEN said:I read through my Holley stuff today, and it looks like it's time to clean the electric fuel pump. They suggest every 6,000 miles. I'm past 8,000 already.
What a racket..Clean the Pump
otfl Viet Nam Vett said:What...??????? Clean The fuel Pump. !! WTF do you have to clean..??
Gas runs thru it...Clean.. What's the Gas do..make it dirty..??
Hope your carrying a spare Pump...:L ..Holley.....What a racket..Clean the Pump
otfl
Freaken Holley....:L
67HEAVEN said:I'm thinking, run it through the dishwasher when the Mrs. is out. Can't hurt, right?
Holley Technical Publications said:MAINTENANCE AND CLEANING INSTRUCTIONS FOR ELECTRIC FUEL PUMPS:
Due to the current poor quality gasoline that’s available, it is recommended that periodically a can of dry gas be used to absorb
the water out of the fuel delivery system. The fuel filter element should be blown clean with compressed air every 6,000 miles and replaced every 12,000 miles to assure maximum protections. If your fuel pump fails to pump or fails to maintain adequate pressure, check the following:
1. Check the voltage at the pump to ensure 12-volt supply.
2. Check the fuel line (especially the fuel filter) for any obstruction. Use compressed air to blow the line free.
3. If this doesn’t solve the problem, turn the pump on and listen for a hum from the top of the pump. If there is no hum, the pump’s electrical system should be checked by a competent repairman. If the pump hums, it probably only needs to be cleaned.
http://www.holley.com/data/Products/Technical/199R7914-3.pdf
Gerry said:All these new fangeled gadjets confuse me. Give me a good old mechanical pump that works for decades and can flow more fuel than an exon tanker run aground in alaska.
You guys are cracking me up.
Best regards,
Gerry
Viet Nam Vett said:Heh Gerry..I'm with you on that.. The only problem is that the 502 does not have a Mechanical Fuel Pump Boss. Or in other words.. The block wasn't made for one.
So Bob and I are stuck with the electric's. The difference is He likes the "Saturn 5 Rocket Engine" sized fuel pump with a tap water sized reducer for the Carb as compare to my fish tank sized pump less the reducer to the carb.
"Hi performance Automobiles have high performance problems" (Mark 2006)
Gerry said:OK, one question I have to ask.
Did either of you guys consider the 540 ?
What made you decide on the 502 in the first place?
Best regards,
Gerry
67HEAVEN said:I'm thinking about crafting a red fiberglass fuel tank for the roof with a 3" PVC running straight into the carb. Then would eliminate the electric pump. :naughty:
67HEAVEN said:Fuel economy.
Best regards,
Gerry
Viet Nam Vett said:Yeah Gerry ..looked at alot of different set ups..including the 540..572.. etc.
There is a limit to how much power you can put down and use. And how you will be using the car. My needs were simple.. A boat laod of torque at low rpm range..street driven with good manors .. a non drag strip car ...just used for street cruzen and trips..etc and a completly assembled turn key motor with proven internals ......and didn't want to twist the frame or blow out rears and throw half shafts.
The 502 is a proven winner. It can be built many different ways or bought as a turn key motor. Becides .. My Friend Bill Got ne a great deal and between Bill and His Friend Mike they did me Right.
So far the 502 has been running like a champ. I still have some tuning issues but they are minor. 67Heaven has over 8000 miles on his motor and as far as I know it's been fine.
Viet Nam Vett said:There is a limit to how much power you can put down and use.
67HEAVEN said:Ain't that the truth.
Bob, didn't you tell me about a year ago "YOU CAN NEVER HAVE TOO MUCH POWER":crazy ?
Gerry
