- Thread starter
- #81
ttt123
- Joined
- Aug 26, 2014
- Messages
- 94
- Location
- michigan
- Corvette
- 1994 base,metallic blue with custom wide body
I think you'll dump more fuel across the OEM fuel map with larger injectors... will it line up in terms of what you need at a given KPA & RPM relative to what your cam and heads need where it is different from the LT1 profile?
Maybe... and maybe not.
An LT1 runs between 41-47psi of pressure from what I have read. If you are running 24lb OE-ish injectors, then you should be able to support 361hp @ 85% duty cycle on the injectors. I'm using Dynamic EFI's Base Pulse Constant (BPC) Utility to come up with this. It calculates supported HP if you supply fuel pressure, injector size, and the number of injectors.
With the LT4 Hot Cam (I think that was what you posted a P/N for in this thread)... many folks seem to run between 380 (not tuned) and 410-ish (tuned) HP from what I have read (ref. other boards such as LS1/LT1).
So, I think you would likely need more injector- or more fuel pressure.
28lb injectors would be fine at 47psi to feed approximately 440hp (per EBL BPC Utility). 24lb injectors would need 60psi to feed 426 (per EBL BPC Utility).
I can hear xfirez51 in my head saying this after my cam and intake swap changes...
But yeah.. you know that you'll need a custom tune to really get it all to work the way you want it to work together.
Hope the calculations above help ya' out in terms of deciding what you want to do next.
Kane, awesome post. Thank you very much. Im not a guru on fuel injection but i read something simular to what you said. Im a second gues it kinda guy so hearing someone else say it is confirmation for me lol.
I do plan on getting a good tune so a little better then stock injectors will happen. I want as much as i can get out of my set up.
