goingballistic said:
Jack, thanks for the info about the gasket sounds like a plan.
Looking at the stock 350, and using a 3.48 stroke, 5.7 rod and 9.025 deck, you come out to 1.585 CH. I'm now making the assumption that the OE piston was a 9.5 domed as that gets you really close to the 8.2:1 CR with a 76cc head. I'm not too sure of the actual OE head on the stock 81 350??? I'm assuming at this point it was about 76cc w/0.039 gasket. I'm taking the heads down to zero deck (9.000), 400 crank ( 3.75 stroke) and keeping the original rods ( new bolts). With a 0.039 gasket, 74cc heads and a +5cc dome (+30 over) I'm looking at about 9.9:1 CR. If I use a flat top, most are -4 or -3 dish, it rasies my CR above 10:1 to almost 11:1 and I'd REALLY like to use pump gas so I'm striving to keep it right at or just below 10:1CR. One quick question you may be able to help with is a statement you made about "don't worry" about about a few CR points..............can you define a "few" slight changes in my spread sheet make the CR go from 9.5:1 to 10.6:1.
Any idea? Thanks for all your help by the way. Paul.
Paul:
No ... the piston I refer to has 1.560" compression height and sits BELOW deck about 0.025". So, if you use the CR calculator here at CAC site
http://www.corvetteactioncenter.com/tech/tools/displacement.html# and plug in 4.03" for bore, 3.48" for stroke, 0.064" for deck height (0.025" + 0.039" gasket), 87cc for combustion chamber volume (76cc head + 11cc piston) and 8 for cylinders ... calculator returns result of 8.2:1 CR ... shazam! If you use a calculator that also accounts for gasket bore of 4.166" ... the CR will probably be a tiny bit less than 8.2:1. Relatively small differences in deck height and/or gasket thickness and/or compression height can have big effect on CR. I wouldn't be too concerned if it's 9:1 or 9.5:1 ... a .5 spread's not gonna make a whole lotta difference in real street-car world.
Speed-Pro piston H602P is hypereutectic DISH top w/ 4 VRs, has compression height of 1.425" and volume of -12.5cc. This piston will zero when deck is cut about 0.025". With 3.75" stroke, 74cc heads on thirty-over, zero deck & 0.039" gasket ... CR about 9.2:1. (I run these w/76cc iron heads, 3.8" stroke ... my CR=9.2:1 also ... amazing coincidence ... no, just math).
Speed-Pro piston H600P is hypereutectic FLAT top w/ 4 VRs, has compression height of 1.425" and volume of -6cc. This piston will zero when deck is cut about 0.025". With 3.75" stroke, 74cc heads on thirty-over, zero deck & 0.039" gasket ... CR about 9.9:1.
Speed-Pro piston L2491F is forged FLAT top w/ 2 VRs, has compression height of 1.430" and volume of -3.4cc. This piston will zero when deck is cut about 0.020". With 3.75" stroke, 74cc heads on thirty-over, zero deck & 0.039" gasket ... CR about 10.2:1.
Glensgages experience indicates his cam's duration probably "bleeds-off" some of his "static" CR ... all cams do to some extent. Most all CR quotes use an index called "static CR" ... another CR index called "dynamic CR" also figures the cam's bleed-off into account ... but dynamic CR is rarely published.
Good job! ... You're definately on the right track by doing your homework on CR before you buy/build ... just make sure you measure correctly and get your math right.
JACK:gap
