Alright, I didn't actually get the alternator Saturday, like I planned.
But I did trace the power wires in the wiring diagram.
It looks like the best method for adding auxilliary connections in this car is to replace the alternator-to-starter wire with a heavier wire (that is, cut the existing wire, and add a second wire directly from the alternator terminal to the starter - unless you plan on yanking your whole wiring harness apart), and then add a second fuse box for the auxilliary loads, also connected to that main terminal on the starter.
My wiring diagram shows the power wire as being 12ga wire. So, looking up the amp ratings, I'd say that 8ga would be fine to make the alternator-to-starter run (10ga would work, too), and 12ga would be plenty to run from there to the second fuse box.
"But those wires aren't rated for 100amps!" you say.
No, they aren't (except for very short runs), and they won't see it, either. Remember that current only flows where you pull it. And the alternator wire splits into several separate 12ga runs that go to various connections within the car. So no one of those wires carries the full current - each draws only what it needs.
The stock alternator is supposed to be rated for around 60 amps, from what I hear. So a 100amp alternator is a 40amp improvement. Look up 12ga wire, and you'll find that it's rated for around 40amps. Add another 40, and you're up to 80. So, figure that this is the new draw through the alternator-to-starter wire, when the acessories are all drawing their full potential. Look down to find 80amps, and you'll see 8ga as the wire.
So, 8ga to the starter. Then 12ga to the new fuse panel, since it will handle the 40 amps which that run will see.
And there you have it.
Now, I just need to get the alternator and wire, and hook it all up.
And remember: the alternator wire that you see actually splits off inside the harness. Unless you plan on pulling the harness apart, leave that wire connected, and just add your new wire to the starter as a second wire. If you'd prefer a cleaner look, you need to yank the existing wire, all the way back through the firewall to the junction. Personally, I think that's more work than I want to do.
The "halfway" method would be to create your own junction by cutting the wire somewhere inside the loom, running your new wire in, splicing the old wire off the new wire, heat-shrinking the connection, and then closing the loom. That way, your 8ga wire will run from the alternator to the starter, and the existing power lead will draw off it, but be hidden inside the harness.
Joe
