I assume this is on your 82. In which case unless there has been some modifications to the distributor, you don't have vacuum advance. Timing advance is electronic from the ECM.New tires, balanced, and aligned.
U joints are certainly on the list.
I'm not sure how the vacum advance works on this engine. Any clues please.
Thank you for the advice.
Sent from my GT-N8013 using Tapatalk
