- Thread starter
- #21
vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
The OLD post!
What it was.....
Block casting
3858174
66 Corvette 300/350 Hp
327 small journal
2 bolt
Crank
Mains 2.29
Rod 1.98
4577 Forged
Con Rods GM markings but ???
30 on top of piston (I'm assuming 30 over)
10-1 comp
Pistons single relief for valves, flat top, Looks cast an SJ in an oval symbol on inside of piston
Pins pressed into rod
Con rod nuts have little slits 1/2 way down
Heads
Double Hump
64 cc
3782461
No acc bolt holes in head
Big straight plugs
Drivers side
175 ( Jan 7th 1965)
Passinger?s side
1275 ( Dec 7th 1965)
Application
62-66 Camaro/Corvette/Truck/Chevy II
Valve size
2.02 Face
1.60 Face
No overlap ( so I?m guessing next size down..it?s the seat area measurement right?)
Small press stud ( aircraft lockdown nuts)
Double spring
Cam unknown ( looks like big lift..have to measure need bits from work for that)
On back of stick c400 p
C-400-P specs as follows:
> Duration @ .050: 222 Int / 222 Exh
> Advertised Duration: 290 Int / 290 Exh
> Cam Lift: .298 Int / .298 Exh
> Gross Valve Lift: .447 Int / .447 Exh
> Center Line C/L: 110 Int / 118 Exh
@1.5 ratio
Carter Carb AFB competetion series
9605S-2794
This is where we are at...today!
Vig!
What it was.....
Block casting
3858174
327 small journal
2 bolt
Crank
Mains 2.29
Rod 1.98
4577 Forged
10-1 comp
Heads
Double Hump
64 cc
3782461
Big straight plugs
Drivers side
175 ( Jan 7th 1965)
Passinger?s side
Application
Valve size
2.02 Face
1.60 Face
Double spring
@1.5 ratio
9605S-2794
Vig!
