- Thread starter
- #121
haganml
Holley
I am having a lot of fun learning this fuel system. Thanks to members of this forum and Holley.com it is coming together. When I was much younger I was working on my Rochester Quadrajet on the 1968 Camaro. I soon became good at getting a crisp response off idle. I liked the spread bore configuration, once I learned it's idiosyncrasies and adapted it was a set and forget fuel system. My friends who had Holley 4150s were ALWAYS tinkering with it trying to get a even idle and crisp tip-in acceleration. Forget the 4160 mechanical secondary dual accelerator pump 4 corner idle 750s! They took their Triple 5s, Chevelles and El Caminos to Forest Richardson (Local Chevrolet drag racing guru) to have them set up. He did a great job and was happy to take their cash. They all sneered and snickered at my "Rottenchester". I was okay with that, after a set of Hooker headers and a 30-30 Duntov cam for my 327/275 I was the one laughing. Of course that ended my career at the Drag Strips, you needed a scatter shield bell housing to run solid lifter cams at OCIR, Irwindale and Lions. You will need to be an old-timer to remember those strips. I love the smell of Nitro-methane on a cool weekend morning! Smells like AA/FA! Wild Willie Borsch was the king of the blown nitro fuel altereds. His all time best was 6.96 @ 213 MPH! That was in the 100 inch wheel base car, he crashed the 94 inch wheel base car made of 1-1/2 exhaust tubing in the 1970's.
Okay back to the Holley. I renewed the 2818-1 for the Coupe. Now there are numerous warnings on the accelerator pump needle pin under the squirter nozzle, but I blissfully ignored those warnings and upended the main body over the garbage disposal. Humh, I wonder what IS that tinkling sound the disposal is making? Hum, a little chrome plated brass rod. Nice! Whine, whine, snivel, snivel! Well Holley has the needle on the web site, part number and everything. The local parts houses wanted shipping on each and every part I needed to order. $9.95 for the needle, $9,95 for the float bowl screw gaskets, $9,95 for the airbleed screw seals. $29.85 for S&H. I was waiting for the parts anyway and Summit only charged S&H once. Now I like to support local business, to a point. The parts arrived the next day from the Sparks NV distribution point, versus 5 to 7 working days for my local guys.
My son's 1964 Chevy II has a Holley on it (80457-3). It wasn't running very well, massive hesitation off-idle, black smoke and nasty idle. The PO told my son that it was because he had installed a "3/4 Race Cam" in the 350 truck motor. I did ask him who made the cam (I don't remember, I got it at a speed shop), what was the lift, duration and lobe separation angle (3/4 Race!) and if he still had the cam card (cam card? waz'at?!). After setting the float levels (way too high), adjusting the air bleed screws to 12 inHg (inches of vacuum) @ 850 RPM, and adjusting the accelerator pump linkage/changing the pump cam I have a tiny off-idle tip-in hard edged hesitation. The fuel is squirting as the throttle is opened, I may have to go up a few numbers on the nozzle. Before the pump adjustment/cam change the fuel was not coming out of the nozzle until 5-7 degrees of throttle opening. The idle is smooth, smells right (not fat and nasty) and sure doesn't have that stutter lope of a "3/4 Race Cam". Curing the vacuum leaks at the manifold and carburetor base had something to do with that I'm sure. I'm only getting 12 inHg at idle so the engine may have a performance camshaft in it after all. The only way to find out is to degree the cam. That is way too much effort, I'm not that interested.
I am working on getting the 350/290 into the coupe. It is nice to have the Chevy II to play with and learn what is up with the Holley fuel system. Very adjustable, adaptable and sensitive to changes.
Mark.
Mark.
ad I will have to go out and get a 7/16 wrench, cut it up, bend the shaft so I can get enough swing to turn the bolt. Put a 6 inch long 3/8 bolt in the front and rear most bolt holes to hold up the ends of the flange to be able to start that miserable blanking blank of a bolt. Modify the alternator bracket enough that I can get my fingers in that tiny little space to actually get it started.
I should have bought the "kit"!
![WP_20140102_001[1].jpg WP_20140102_001[1].jpg](https://forums.corvetteactioncenter.com/data/attachments/6/6837-1e28cbd1cf02fbc602696c13dd6ea6b6.jpg?hash=HijL0c8C-8)
